1. MyQuestions's Avatar
    Hi, The logo / icon is a green head and the mask is grey. It is located on the line with information such as time, wifi strength, date, etc. It is in my 'chatroom' on my friend's phone, she sent me a screen shot of something and I noticed it. Does this mean a 3rd party app is being used to block me / freeze last seen? I have not asked her yet. There are times that her last seen is the same for hours even a day, though I know that she is very active on Whatsapp. I have a screen shot but don't know how to upload it here. Many thanks. First question!
    12-11-2016 02:13 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved to the WhatsApp forum. It may help to see a screenshot: http://forums.androidcentral.com/gen...d-central.html
    12-11-2016 05:26 PM
  3. MyQuestions's Avatar
    Thank you
    I'll try to upload the image
    12-23-2016 05:20 PM
  4. MyQuestions's Avatar
    Whatsapp - There is a small masked man logo/icon, top left corner - Samsung S7Edge-aaa-mask.001.jpeg
    Hello - I hope that this is the image of the "masked man" ... I uploaded from my computer.
    Thanks
    12-23-2016 05:50 PM
  5. B. Diddy's Avatar
    Thanks for the screenshot -- hopefully someone else who knows the app well can answer. My guess is that you're in some sort of incognito mode.
    12-23-2016 05:53 PM
  6. MyQuestions's Avatar
    Thanks, B.Diddy. I hope someone can help - this is not on my phone. My friend sent me a screen shot and this is what she has on my profile on her phone. I think it might be a way to block me (some of the time)?
    12-23-2016 06:04 PM
  7. empowercb's Avatar
    Hi there... this icon since appearing in status bar/ notification panal of phone.. i believe have nothing to do with whatsapp or ur profile/chat.. Please ask her if this appears only when whatsapp is on screen or it is there all the time? Like while using any other app?... my vague thought is.. it might not be some kind of spyware..
    Suggestion: remove any unknown apps/ apps from non trusted sources.. Apps containing too much adwares and if any app seems fishy or malware.
    Always install apps from a reputed app store and the knkwn ones and those which are reputed or atleast the developer is known and/or reputed.
    12-23-2016 06:41 PM
  8. MyQuestions's Avatar
    Hello empowercb, Thank you for replying. I haven't asked her if she installed anything as I'm not sure if it is spyware or if she has blocked me or anything like this. I wondered if it was anything to do with a third party app she may be using to freeze her 'last seen'? As I mentioned, she is an avid whatsapp user but often her last seen is the same for 10-12 hours or even a whole day.
    If no one here has seen this, then I will just ask her.
    Thanks for your response.
    12-23-2016 07:10 PM
