Wireless Car Charging Dock
mwyarm
12
4
I just recently purchased a LG G3 and I am looking to replace my current car dock from an Motorola model but with wireless. I plan to use the suction cup to attach to the windshield as it is the most convenient location for me and to my left which is not distracting. I have found Tylt and Ottie and still searching for reviews of what else is available. So, the requirements I am looking for are:
1) Windshield suction cup that minimizes shakes and holds to the windshield in a heated summer environment
2) Wireless charging - 3 conductor preferred
3) Prefer charging wire to Wireless Dock to be hidden behind the dock or at least on the bottom - out of sight as much as possible
4) Standard charging plug but will go with whatever brand it requires
5) Compatible with LG G3 with a Spigen cover or Outerbox. I have read positive reviews on some that it can detect the charging coils even using a thick Outerbox.
6) Maintains charge or minimal battery drain over a 1 -3 hour period.
7) One hand operation to insert and one hand to remove
Any suggestions that meet the above or most all of the above?
Thanks
