1. mwyarm's Avatar
    I just recently purchased a LG G3 and I am looking to replace my current car dock from an Motorola model but with wireless. I plan to use the suction cup to attach to the windshield as it is the most convenient location for me and to my left which is not distracting. I have found Tylt and Ottie and still searching for reviews of what else is available. So, the requirements I am looking for are:
    1) Windshield suction cup that minimizes shakes and holds to the windshield in a heated summer environment
    2) Wireless charging - 3 conductor preferred
    3) Prefer charging wire to Wireless Dock to be hidden behind the dock or at least on the bottom - out of sight as much as possible
    4) Standard charging plug but will go with whatever brand it requires
    5) Compatible with LG G3 with a Spigen cover or Outerbox. I have read positive reviews on some that it can detect the charging coils even using a thick Outerbox.
    6) Maintains charge or minimal battery drain over a 1 -3 hour period.
    7) One hand operation to insert and one hand to remove
    Any suggestions that meet the above or most all of the above?
    Thanks
    07-14-2015 12:30 AM
  2. zrxoa1's Avatar
    Air Dock
    10-13-2015 07:40 PM
  1. Why is my phone not charging properly?
    Last Post: 03-10-2016, 10:23 AM
  2. Is the FitBit Charge HR combatable with Motrola Droid Turbo?
    Last Post: 07-18-2015, 03:29 PM
  3. Why wont my Galaxy S4 charge?
    Last Post: 07-13-2015, 09:10 PM
  4. Can the charging port on my S5 be dried out?
    Last Post: 07-13-2015, 08:23 PM
  5. Does the LG G3 D852 From bell mobility take wireless charging?
    By The Commander in forum Android 5.0 Lollipop
    Last Post: 07-13-2015, 06:59 PM
