1. 1122334455667788's Avatar
    I'm trying to find a wireless charging pad that connects to a USB-C cable.
    The chargers I see either don't specify, or say Micro USB.
    Getting another Micro USB accessory doesn't seem to make sense at this point.
    Has anyone found a good wireless charger that uses USB-C?
    10-13-2017 08:29 PM
  2. Golfdriver97's Avatar
    In this case, I don't see why it can't be Micro USB. It's power output is high enough to give a fast enough charge.
    10-22-2017 09:41 AM
  3. chanchan05's Avatar
    IMO it doesn't make sense to be picky about whether a wireless charger uses microUSB or not. You're not gonna use the cable for it on anything else, and it's unlikely to ever leave your desk, and you won't be exposing the cable to being wrapped up a lot since you can just tape it along the back of the desk or the leg of the table, so that cable is going to last.
    Basically it wouldn't even matter if the charging dock's cable isn't even detachable.
    10-22-2017 09:50 AM
  4. 1122334455667788's Avatar
    Sure it's not a big deal.
    Most of the time it won't make any difference at all.
    If wireless charging is slower than wired charging (I think it usually is), then occasionally (when I'm in a hurry), it would be nice to be able to unplug the wireless charger and use the wire to directly charge the phone.
    Obviously I could just keep a spare type-c cable handy, but if given the option I'd rather have one less cable kicking around and potentially getting lost.
    I finally found a type-c wireless charger from CHOETECH. It hasn't arrived yet though, so I can't say how well it works.
    10-22-2017 10:29 AM
  5. 1122334455667788's Avatar
    10-22-2017 10:29 AM
  6. SFCable's Avatar
    checked on amazon
    07-20-2019 02:57 AM
  1. S7 wireless charger doesn't work with my S8
    By Abdo23 in forum Samsung Galaxy S8 & S8+
    Last Post: 03-06-2018, 10:19 PM
  2. Moto z2 Play not charging with Car USB
    By Android Central Question in forum Moto Z2 Play
    Last Post: 10-25-2017, 05:11 PM
  3. Why won't my USB headset work OTG with my Honor 6x?
    Last Post: 10-13-2017, 10:58 AM
  4. Moto z2 Play not charging with Car USB
    Last Post: 10-13-2017, 09:46 AM
  5. Aftermarket charger damage my battery?
    By Dinkyy3 in forum Samsung Galaxy Note 8
    Last Post: 10-12-2017, 09:42 AM
