1. ankit3302's Avatar
    hey everyone i'm using 3s prime and there is always notification bar on top side and shows download unsuccessful and it never disappear on my phone don't know why this notification is coming. Is there any solution?
    06-16-2018 05:43 AM
  2. mr_master's Avatar
    What app is the notification from? You can try to long-press the notification to see which app sent the notification. Then go to Setting > Apps > find the app that sent the notification > Force stop. Force-stopping the app should make the notification disappear, but it may or may not reappear. Or you can also try restarting your phone to see if it will disappear.
    06-16-2018 05:52 AM
  3. Rukbat's Avatar
    Also, while you're in Apps for the app, clear the cache.
    06-16-2018 01:24 PM
  1. What is up with the bland widgets??
    By B0WIE in forum LG G7 ThinQ
    Last Post: 06-16-2018, 08:46 PM
  2. Where is the Google frog and why does it always disappear from Steve fleming
    Last Post: 06-16-2018, 05:30 PM
  3. All websites Are Not working in my mobile like Only Youtube are accessable
    Last Post: 06-16-2018, 01:35 PM
  4. Why is my LG Startup screen stops
    Last Post: 06-16-2018, 06:02 AM
  5. how do i change from black and white back to color on my lg m322
    Last Post: 06-16-2018, 05:42 AM
