1. Stefan Gvozdenovic's Avatar
    My charger is broken, i need other.
    Do you have advices which to choose?
    What do u think about this:
    https://www.aliexpress.com/item/Orig...0-571c0cd08936
    I read on internet that for my model is maximum 2.0, this is 2.1, do i make damage to my phone. Also, i think my phone dont support fast charger if i not wrong..
    Thanks...
    Original is:
    100-240V 50/60 Hz
    Max 0.35A
    5v"- A2
    Or this link:
    https://www.aliexpress.com/item/Orig...5-2439c5ec195c
    10-20-2018 06:25 PM
  2. Mooncatt's Avatar
    Any charger will work. Don't worry about having a higher amperage than your original charger, because it's the phone that determines how much amperage to pull. It could be a 10A charger, but the phone would still only pull 2A (or whatever it's design) max from it.
    Stefan Gvozdenovic likes this.
    10-20-2018 07:39 PM
  3. Stefan Gvozdenovic's Avatar
    Thanks, i have another question.
    How to see do i install right rom for my MTK, i dont sure do i make mistake and install Snapdragon rom.
    10-21-2018 08:12 AM
  4. Mooncatt's Avatar
    I don't know much about installing different ROM's. All I can tell you is they are very device specific and you have to install one programmed for your specific model number. There is no generic ROM for phones, and there isn't even a guarantee that one is available. They are made by independent programmers, so your results may vary.
    10-21-2018 02:48 PM
  5. Stefan Gvozdenovic's Avatar
    I buy charger, but i hear something, what is it?
    11-09-2018 11:29 AM
  6. Mooncatt's Avatar
    That's a car charger, right? If so, could you tell for sure the sound was coming from it and not through the radio? If it's coming from the charger itself, that's definitely not right and I'd exchange it.
    It is common to get that type of noise through the radio as electrical interference under certain conditions, but usually involves having the headphone jack connecting the two and listening to the aux input on the radio while also charging the phone (higher quality radios do have a filter to stop this).
    11-09-2018 11:45 AM
  7. Stefan Gvozdenovic's Avatar
    No, its regular charger for phones.
    I buy this for this link:
    https://www.aliexpress.com/item/Orig...34ea4c4dfGFsIX
    So its not secure to use this charger?
    11-10-2018 01:53 AM
  8. Mooncatt's Avatar
    Ok, my mistake. Yeah, I wouldn't use it personally. I've never had one make any noise like that, so I'm thinking something is defective.
    11-10-2018 08:51 AM
  9. Stefan Gvozdenovic's Avatar
    Do someone have reccomend for charger?
    I was think about this:
    https://www.aliexpress.com/item/ORIC...6e5a3c00wQmQ5I
    But he is 0.2A, original xioami is 0.35A, whats the differences?
    Or, what about this> https://www.aliexpress.com/item/Ugre...d-6977788b1965
    But he is 2.1A, original Xiaomi is 2A??
    or this?
    https://www.aliexpress.com/item/Orig...d-6977788b1965
    11-19-2018 04:38 AM
  10. Tylor Turpin's Avatar
    Suggest you to Use voltage or surge protectors when charging devices, especially when in doubt of the quality of your charger.
    11-19-2018 04:53 AM
  11. Mooncatt's Avatar
    or this?
    It's never a bad thing to get a stronger charger. The phone is what determines how much current flows through, so there's no risk there. A weaker charger would just charge slower, or still cause you to loose charge in worst case scenarios.
    11-19-2018 07:49 AM
  12. Mooncatt's Avatar
    I doubt that would make a difference. Surge protectors stop problems before they get to whatever is plugged in. If you plug in a defective charger, it is still possible to damage your phone even with it plugged into a surge protector.
    11-19-2018 07:50 AM
  13. Stefan Gvozdenovic's Avatar
    Phone decide how much power will go?
    So i can use 18w charger, phone will get what they need and i dont need to worry?
    11-19-2018 10:28 AM
  14. Mooncatt's Avatar
    Correct, up to the limit of the charger of course. Look at it this way, consider your home electricity. Not sure about where you live, but in the U.S., our standard circuits are rated at 110V @ 15A. That's up to 1,650 watts of available power on each circuit. If actual current (and to a certain extent, wattage) was determined by the delivery source, the phone charger would be blown as soon as you plug it into the wall.
    11-19-2018 10:50 AM
  15. Stefan Gvozdenovic's Avatar
    Wow, thank you for learning me some things.
    Now, can you just confirm me, can i buy this charger and put usb on 2.1 and be happy?
    https://www.aliexpress.com/item/EU-P...7-dbcf354ccf26
    On Original charger is 0.35 A, here is 0.5 A this is the reason why i am afraid..
    11-20-2018 04:43 AM
  16. Mooncatt's Avatar
    From a technical design standpoint it would be fine. I'm not familiar with that brand or the website, though. Considering the price I saw for it, I would have some concerns about durability and defects, so check the reviews and such to see if it's a reputable brand.
    11-20-2018 07:30 AM
  17. Stefan Gvozdenovic's Avatar
    Reviews are very good, this is the reason why i looking this charger.
    It have 7k+ reviews, and 91% give 5stars..
    11-22-2018 05:01 AM
  1. Best guess at Black Friday deals on Note 9?
    By Cajun_Mike in forum Samsung Galaxy Note 9
    Last Post: 11-26-2018, 08:16 PM
  2. Samsung Note 5 file transfer with no screen
    Last Post: 10-24-2018, 10:06 AM
  3. S4 gives me the green robot update note and then hangs
    By michaelschuyler in forum Verizon Samsung Galaxy S4
    Last Post: 10-21-2018, 06:42 PM
  4. Script for auto answer note 8
    By Goodguy1405 in forum General Help and How To
    Last Post: 10-20-2018, 03:28 PM
  5. My REDMI NOTE 4 Shows some menu in Another Language
    Last Post: 10-20-2018, 01:22 PM
