1. Stefan Gvozdenovic's Avatar
    Situation is this:
    Phone suddenly start to heat (41C battery), and lose battery life very fast.
    I reset this, change charger, and situation is the same.
    Somethimes it heating when i do nothing, its cold, and suddenly heat, often is this when i charge phone, than become hot, so i turn off and turn on when he bacame normal, and work good, until suddenly start to heat. Advices?
    10-25-2018 08:15 AM
  2. B. Diddy's Avatar
    It sure sounds like a failing battery. Bring it to a repair shop to replace the battery (or look at some DIY videos on the web to try to replace it yourself).
    Stefan Gvozdenovic likes this.
    10-25-2018 08:39 AM
  1. Weird text message through S3 from Note 8 (AT&T SYNC) Help
    By jaredherrera91 in forum Samsung Gear S3
    Last Post: 10-27-2018, 12:23 AM
  2. Note 9 book
    By cardboard60 in forum Samsung Galaxy Note 9
    Last Post: 10-26-2018, 09:32 PM
  3. Replies: 2
    Last Post: 10-25-2018, 09:14 AM
  4. Weird text message through S3 from Note 8 (AT&T SYNC) Help
    By jaredherrera91 in forum Legacy Android & Other OS's
    Last Post: 10-25-2018, 01:55 AM
  5. Why did BEST BUY cnc one of my NOTE 9 preorders
    Last Post: 10-24-2018, 10:54 PM
