    I Am getting a blank popup msg in the messages app, with yes or no options after every sec how can I get rid of it?
    Every time I click No n click on the screen it pops up again
    This appears only in the SMS app
    01-06-2019 10:13 PM
  2. FireLight25's Avatar
    Are you using dark or non-system theme? (Don't LOL me if you are doing it right now but it also happens quite a lot.)
    If you are using aftermarket sms app, then maybe that app is sending you popups, but it is less likely. Very few sms apps are there that people trust anyway.(and not a lot of people actually send sms texts these days). Second possibility is that your mobile carrier is sending you some plan/offer notifications and want your consent to start that service. If you are not able to see/read it. I'd suggest never say yes.
    01-16-2019 01:22 AM
  1. Deleteing storage and/or data in apps.
    Last Post: 01-07-2019, 07:09 AM
  2. Why is my battery life is not able to up while i playing
    Last Post: 01-07-2019, 07:01 AM
  3. I am on a tablet and there is no enter key to post, ?
    Last Post: 01-06-2019, 06:42 PM
  4. Pictures in 2 albums
    Last Post: 01-06-2019, 06:13 PM
  5. Not able to enter a PIN to pair LG HBS1100 with Samsung 9+
    Last Post: 01-06-2019, 06:02 PM
