1. Justhavocman's Avatar
    Hey everyone , bought my redmi note 7 a couple of days ago and the first huge difference i see when compared to my note 4 is that the battery drains so much faster in idle\standby , i've disabled all of battery consuming options i've found searching the web but the issue still persists , is it the new update , is my phone faulty?
    Here is the battery performance\graphs from yesterday , the phone finished charging at 20;00 and by ~22;00 it had lost 10% of battery simply doing nothing , being idle
    and here's the ones from today
    08-16-2019 02:46 PM
  2. mustang7757's Avatar
    That wifi is little high ,you have strong wifi connection?
    08-16-2019 03:14 PM
  3. Justhavocman's Avatar
    Yeah , the router is in my room so i'm getting pretty much perfect connection.
    Edit : I think i answered my own thread , i just finished doing my 2nd factory reset and the battery problems still persisted , i lost 3% of battery in the time it took the phone to do the setting up . I am now 99% convinced that it's a faulty phone or a faulty battery and will be returning it first thing on Monday.
    08-16-2019 03:17 PM
  4. mustang7757's Avatar
    Ok..one more test you can perform is put in safe mode , see if any apps causing this .
    08-16-2019 03:54 PM
  5. Justhavocman's Avatar
    So here's the battery usage of the past 6 hours ( after it was charged to 100%) of the phone just sitting there on idle , doing nothing , with no background apps etc , booted on safemode.
    Attached Thumbnails Idle battery drain too high?-screenshot_2019-08-18-00-19-34-217_com.miui.securitycenter.jpg   Idle battery drain too high?-screenshot_2019-08-18-00-19-37-000_com.miui.securitycenter.jpg   Idle battery drain too high?-screenshot_2019-08-18-00-19-29-634_com.miui.securitycenter.jpg
    08-17-2019 04:23 PM
  6. mustang7757's Avatar
    System app updater ? Can you find this?
    08-17-2019 06:15 PM
  7. Justhavocman's Avatar
    Just got the phone back from service , there's nothing wrong with the battery or the phone overall , they even had the phone set to their wi-fi and it drained 55% in about 48 hours. So the thing is , when i turn it on to my own wi-fi the battery drains like crazy , the moment i turn off my wi-fi it stops . It's only on my own wi-fi that the battery goes haywire .
    08-21-2019 06:00 AM
  1. Gear 2 Frozen after battery replacement
    By Android Central Question in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-26-2019, 07:41 PM
  2. battery charging itself when shut down
    By labas10 in forum Ask a Question
    Last Post: 08-17-2019, 11:13 AM
  3. Replies: 2
    Last Post: 08-17-2019, 02:28 AM
