1. whois1230's Avatar
    Hello, my battery is charging really slow. It was 47% and after 1 hour of charging it's 56%. What could be the reason for this? My phone is over 2 years old, so the warranty is not valid any more.
    03-23-2020 04:38 PM
  2. mustang7757's Avatar
    Have you tried another cable and charger?
    03-23-2020 04:56 PM
  3. Bolt Strike's Avatar
    Hello, I had the same issue. Also when plugged in there was message 'cable' charging instead of 'fast'. I am not sure what was the problem but changing cable resolved it.
    mustang7757 and GloomyCarry like this.
    03-23-2020 05:02 PM
  4. mustang7757's Avatar
    Good to hear that , thanks for your feedback.
    Bolt Strike likes this.
    03-23-2020 05:25 PM
  5. blackhawkhot's Avatar
    That was already suggested, thanks.
    Note: If you're fast charging you need a compatible charger and a cable that supports fast charging. If not the phone senses it and will not fast charge.
    04-19-2020 12:17 PM
  1. Rapid battery drain below 30%
    By High_tech_lowlife in forum General Help and How To
    Last Post: 03-29-2020, 10:27 PM
  2. Replies: 3
    Last Post: 03-27-2020, 08:00 PM
  3. S20 plus maybe battery drain
    By Liorid in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 03-22-2020, 02:21 PM
  4. Reverse charging and MIDI, HELP!!
    By gmg_87 in forum General Help and How To
    Last Post: 03-22-2020, 01:39 PM
  5. I'm very happy with my S10
    By Owen Kim in forum Samsung Galaxy S10 & S10+
    Last Post: 03-22-2020, 09:50 AM
