1. tfx1's Avatar
    Flashed Build HWI69 for US Retail on a Canadian wifi MZ604 xoom..tired of
    waiting for 3.1 update.
    adb reboot bootloader
    fastboot oem unlock
    Xoom will then reboot into bootloader screen
    fastboot flash boot boot.img
    fastboot flash system system.img
    fastboot flash recovery recovery.img
    fastboot flash userdata userdata.img
    fastboot erase cache
    fastboot oem lock
    fastboot reboot
    It is stuck on Starting RSD mode 2.
    I can not get it to fastboot protocol...and device does not turn off.
    Any solutions?
    06-08-2011 12:29 AM
  2. 2CupsWithString's Avatar
    Press volume up & power so the Xoom reboots.
    After it reboots, right when the red logo shows up press the volume down button, it should toggle between the different modes the Xoom can enter. Hopefully you can get it back in to fastboot or recovery. You'll need to update your Xoom's bootloader/hboot to make it work with a different version.
    06-08-2011 07:21 AM
