1. AC Question's Avatar
    my phone will randomly shut down then say unfortunately phone launcher has shut down and wont turn on im wanting to know if this is fixable
    Ungreatful_Dead66 likes this.
    08-01-2015 05:54 PM
  2. Raptor007's Avatar
    I would suggest you clear the cache in the system to see if that addresses it, if not something may have messed up the built in launcher, have you tried any 3rd party launchers or installed any recent apps since this started to happen? You can give the full factory reset a go as well and fortunately Play store allows you to fully restore all of your apps based on prior phone setups. Here is a quick guide on factory resetting http://forums.androidcentral.com/amb...id-device.html
    08-01-2015 06:10 PM
  1. It keeps turning off games
    Last Post: 08-01-2015, 06:54 PM
  2. Replies: 0
    Last Post: 08-01-2015, 05:50 PM
  3. How do you get out of video mode on an Andriod Maxx?
    Last Post: 08-01-2015, 05:41 PM
  4. Replies: 0
    Last Post: 08-01-2015, 05:36 PM
  5. How can I see my pictures I saved on my phone from my phone?
    Last Post: 08-01-2015, 05:08 PM
