- Sep 20, 2016
- 1
- 0
- 0
How do i fix this? Everytime i mount my SD card it becomes the default installation of OBB and Data file
My phone is Acer Liquid z630
I really want it to be Internal Storage since the loading and performance is faster that way
My internal storage has 4gb space left and the obb/data file is only 1gb
If i unmount the SD card the app/game will then recognize internal as the default location of OBB/Data file
Also the default write disk in the settings is phone storage
On es fle explorer:
When SD card is unmounted - Internal is the Sdcard0 which is the default installation
When SD card is mounted - The internal automatically changes to SDcard1 which should be the Sd card not the internal
Is this the Phone model problem? or Android 5.1 problem?
I really hate this since if i mount the SD card again the problem resurface
On es fle explorer:
