help how do i get rid of grid lines on samsung Galaxy S3?
chris41798
Ok my mom is having troubles with grid lines
At this very moment I'm under developer options in my mom's phone settings and I found something that says show touches which states as the following: show visual feedback when screen is touched
chris41798
At this very moment I'm under developer options in my mom's phone settings and I found something that says show touches which states as the following: show visual feedback when screen is touched. I have turned that off and on and the blue lines still do not go away what else could I do to make these blue lines from appearing on my mom's phone??
Prasant
Thanks a lot my dear friend. My son has a HCL tab which also occured the same problem for which I faces many problem but your post help me a lot.
Dec 25, 2014
Re: help how do i get rid of grid lines on samsung Galaxy G530H
I have read the feedback in the forum but I do not have the option of "Developer Options" under settings..I am finding these lines a big nuisance.What is the methodology for G530H to get rid of these lines?Thanks.:mad:
SearingMedia
8
To get developer options, go to Settings -> About Phone -> Then tap on the "Build Number" cell 10 times.
elane500
I have an s5 and random pictures are showing with half or all grey over the pictures. I can't seem to figure out why this is happening.
Jennifer Vivian
OMG thank you so much! I let my son play on my phone and he messed it all up. Thankfully I found your response on how to get rid of the grid. Thank you!!!!!!!!!!!!!! I was freaking out, I thought for sure he broke it.
shania ponce
I cannot get rid of what appears to be grid lines... at the top of the screen is a bar with with y and x and the numbers change as you move your finger on the screen creating a grid as you move
It is like a free tx at the same time ie a blue line is left wherever i run my finger no matter what app I am in.
I did have the app "Free tx" which I have deleted but hasn't:mad: solved the problem
Please can anyone help me?
What u do is u go to build number tap that 4 times and go to developers option u go there and u see the on and off button turn it off and ur good
jue7
help how do i get rid of grid lines on samsung galaxy grand?
i already read and follow the wht stat on comment but the line still there
Hamuy Foreveryong
3
I have the same issue.
