How can I get out of system recovery mode on an Android Nextbook?
Justin D English
My Android Nextbook ran out of power (Only the third time, so I wouldn't think that is the problem), so I let it charge, but now it is entering the system recovery mode and it won't exit. At the bottom of the screen it displays this message:
E:Bad bootloader arguments
"(null)"
E:unknown volume for path [/udisk/factory_update_param.aml
E:Can't mount /udisk/factory_update_param.aml
Would greatly appreciate it if you guys could help me find a solution!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
27
It looks as if the filesystem was damaged. Reflashing the ROM would probably fix it.
Did letting the battery run down to 0 do it? There's no way to tell, but probably not. But doing that even a few times will have an impact on battery life. Try to recharge it when it's down to no less than 40% for maximum battery life.
glda19
