I have owned my Sony Xperia Tipo (ST21i) for two years now. It worked fine until I started facing this problem about a week ago. I had added 195 songs to my phone, out of which 118 were stored in the external SD card. Last week I added two more songs to my phone using the PC Companion. Occassionally when you tap on a song or on the Shuffle button the song plays immediately. However, after I added those two songs, when I tapped on one of them to check them out, instead of playing immediately, all I saw was "Loading…". The problem is instantly solved when I delete the new songs, but it's still annoying how I can't add any more songs because of this minor issue. I only managed to add one song without problems, but it still isn't normal having to wait until the songs load. There's like four other songs that I want to add!
I was wondering if repairing the phone using the Sony PC Companion would help, but it's difficult to back up everything before repairing since there's a chance I'll lose my data. What should I do to fix this problem? Is there probably a limit in the file size or something that causes it?
[UPDATE] I repaired my phone with Sony PC Companion, but the problem wasn't solved.
