Android 'jellybean' tv box....wont work properly....help please...
Jud63
The jellybean box itself turns on and the home screen loads up. I select the page where all the apps are...select xbmc app...sometimes it flicks back to main apps page other times the screen turns black/blank. I can't get further than this page....my box has worked perfectly for the past 3 months since purchasing. I can't get into the settings page as I can't get past the blank page, its so frustrating. Has anyone any hints or tips to get my box working again. Many thanks in advance, Jud.
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
You can't access the settings app of your device or of the xbmc app?
drkrleitch
