Hi!
Here is a picture of two devices. On the left, an Archod with many "USB computer connection" options and on the right... my Motorola Moto E. As you can see, there are some significant differences:
On both devices, the USB debugging mode is enabled, I'm already considered a developer (About Phone > Build number > several taps > "no need, you are already a developer"), the only difference is that on my Motorala, some options are missing in this specific menu.
How to display those options? I really need to connect in Advanced Debug Mode (instead of "as in media device") in order to use Unity Remote 4. It doesn't work as it should and i'm pretty sure it comes from there.
Thanks in advance for your help! :'p
Rag
Rag
