Smart lock, notifications. Not seen this question anywhere.
With smart lock enabled, and working properly, you get the options to display all/sensitive/none notifications on the lock screen. This is all simple so far (eventually!).
My question is this. The settings say "when device is locked" which i assumed to be locked as in, smart lock enabled but outside of the trusted locations or devices radius etc. It seems to mean, simply the lock screen even when smart lock is in effect.
What i'd want to happen would be at home, or with trusted devices, the lock screen shows all notifications, but when a passcode is required outside of that, the notifications switch to sensitive or none.
Why does this setting not take into consideration that smart lock means the phone is technically *not* locked at these points? Lock screen shouldn't mean *when locked* if a pin code is not going to be required.
Anybody else think the same? Or am i missing something?
Thank you.
Thank you.
