A
AC Question
well i tried my galaxy s5 in the pool and he was completly sealed by the panel and the charging panel , and then after a few hours he didnt readed the micro sd card .
it even dont see that there is an sd card , nothing at all !
i used the sd card and it worked perfectly .
i tried putting my sd card on my brothers galaxy s5 and it worked completly normal , i tried removing the battery , factory reset , cleaning it with hair fan , nothing worked ....
please help its very important !
