About two weeks ago I bought a Samsung Galaxy S3 Mini Value Edition.
Since then, I found several issues with it:
-a white horizontal line appears on the unlock screen, but it disappears one second later.
-when the unlock screen appears, the text flashes one time, but then everything is normal until the "enter the pin code" text disappears permanently.
-when I first put music on it, I went to the music player and pressed the letters "G" and "S" to easily reach the songs, but then the letters disappeared and got replaced with "-". It shows the same in contacts, too.
-I don't know if it's just me, but I can see small small pixels on the screen, contacts icon, when typing, etc. The image isn't really smooth.
-the home button doesn't stay in the same place, it can be moved. Maybe this happens on all phones, not sure, though.
I'm worried about this. It's under warranty, of course, do you think they can replace it with a new one? Please help me!
