Time card? You mean your SD card or your SIM card?
I was just suggesting a reboot, not a factory reset. Just power the phone down by pressing and holding the Power button until you see the Power options, then tap Power Off. For good measure, once it's off, remove the battery and wait 10 seconds. Then put the battery back in, and turn the phone back on. Is the audio still messed up?
