Why can't my Xolo q700 connect to my PC through USB cable?
A
AC Question
My xolo q700 can't connect to my PC through USB cable.
What can i do?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Re: My xolo q700 can't connect to my PC through USB cable.
Welcome to Android Central! What version of Windows? When you connect via USB, does any USB connection notification appear on the phone? Have you tried a different cable, or different USB ports on the computer? Make sure you're not using a USB hub.
Jayesh21
Why can't my Xolo q700 connect to my PC through USB cable? and XOLO secure is disable, How it's enable
may i tray on windows 7 ,windows 8/8.1 and windows 10
Jayesh21
XOLO Q700 xolosecure app not work
after factory reset phone xolo secure stop and try sign in to google account gat error this page can'tbe found.
this page doesn't exist in google App administrator help.It may be deleted because the feature doesn't exist anymore,OR the URL may be incorrect
After this error my phone not connect on pc with USB Cable
Ian Morgan2
254
Re: XOLO Q700 xolosecure app not work
Having done a reset....you'll be able to get to your Google Account on another previously authorized device.......be that your pc or another ?
Having wiped data, your pc isn't recognizing your phone.
When you are able to visit your Google Account you will be able to set the devices you wish to be associated with the account........and other settings.
123dzo
