Considering buying an S6, can I get some help with a few questions?
A
AC Question
Considering buying a S6, need some help
I have unlimited data on my current verizon S4 and want to keep it so I am thinking of buying the S6. I have never bought a phone at full price and wanted to know what advantages there are. I realize I am not tied to the carrier for two years but do I get a phone wheer I can remove the bloatware if I wanted to since it is my phone?
Thanks,
Steven
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
Re: Considering buying a S6, need some help
Thanks,
Steven
The plan will continue on until you change your plan yourself. If you buy a Verizon version unlocked, it will still have all of the Verizon apps pre-installed. If you buy the international version, it will come without it.
Sent from my splendid Note 4.
wacky23
