A
AC Question
I had some trouble charging my phone for a little while. I would plug it in over night with 10%, but in the morning it would only be at 30-something% (it varies). I thought it was a problem with the charger and used the USB charger instead of the wall socket. The problem got better but then it repeated. I then thought it was a problem with the battery and so got a new battery, charged it with that, and then used the other battery. It worked fine for a while. But now recently I have tried to charge it over night with 15%, but it dies during the night and when I try to charge it, it won't turn on. I switched the battery to the original one and let it charge. When I put the original battery in, it had 1%. After only 2 minutes, it said it was at 17%. I let it charge a bit more and it was at 26%. As soon as I took it out of the charger, it suddenly jumped up to 50%. I plugged it back in to see if it would charge more, but it just started going down. The next day I charged it over night (starting at 6%), but it died during the night and all day I have been trying to charge it and turn it on. Neither the wall charger or the USB charger will work. Please help me <3
