A
AC Question
Nothing on my phone will operate.
I have an HTC android adr6300 its pretty old. But whenever you try to use the keyboard only a bunch of Q's come out and I've tried doing the tutorial thing but it won't even let me type on there, also anytime I turn off the phone and turn it back out/ all the apps I deleted or removed are back on it again. It says im low on space and I cant factory reset anything because nothing deletes, it all is there again. NOTHING WORKS.
