A
AC Question
When I plug the portable speaker (Fujitel Cube 3) or any other sound device that have a Jack 3.5 - miniUSB conection, it only sounds for 5 seconds, then my cellphone stops the music (like when I disconnect the jack), if I press the play buttom it starts playing the music for the cellphone speakers.
My cellphone is a Huawei Y330, and the SO is Android 4.2.2
Note: It only happend with jack-miniusb, when i use it on headsets or 2x1 jack it works fine.
