Unlocked CDMA/GSM/LTE phones for use on Sprint?
A
AC Question
I was looking at the HTC desire 510 on Sprint which is the CDMA (LTE?) version, then I went to HTC to look at the Unlocked version & saw that the unlocked has GSM, CDMA, WCDMA & LTE that looked the same.
It was the Programing .
Has anyone tried to use a Unlocked phone with CDMA/GSM/LTE combo on Sprint?
With CDMA Shutting down in the next fer years, will Sprint join the GSM/LTE club?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: Any one know if any Unlocked CDMA/GSM/LTE phones work on Sprint?
The Nexus 6 and Nexus 5 will work just fine. You can find both at Sprint; or purchase either online via the Play Store. If you are interested in the Nexus 6 it recently came down in price, so that's something to consider if you are looking for a good off-contract phone.
Non
