Why does my old Droid connect to other Wifi networks but not my own?
Apr 22, 2022
14
I have an old 2017 Android phone (Moto E4 Plus for Boost Mobile, who I've since left) that for whatever reason won’t connect to MY home Wifi network.
• I brought it over to a buddy’s house (who uses Spectrum internet like me), and it got on his Wifi and was surfing the web right away.
• I even took it to a Starbucks & it got online using their Wifi.
Yet at our place, it saves our Wifi name, but seconds later that’ll show as “Disconnected” or Disabled,” won't pull up any web pages, shows a MAC address that I can’t edit but no IP address (despite having smartphones both newer and older than this, laptops etc that all connect to the same Wifi…).
• I’ve reset the modem.
• I’ve reset the router.
• I’ve Reset Default Networks and done a Factory reset of the phone itself.
• I tried connecting both w/ and w/o the old Sprint SIM card inside (only because some of the before & after error messages said “V08” or “Mobile ID Download Error, an unexpected download error has occurred. [Code: 10],” both of which seem to pertain to the carrier).
Still can’t get it online at my current place.
• I tried changing the Proxy (from None to Manual or Proxy Auto-Config), the “IP settings” from DHCP to Static, tried typing in the same IP address/Gateway etc as one of my connected phones, and that didn’t work either (though admittedly it’s not like I understand what all that means anyway).
Now: I WAS able to get it online at my old apt.—we moved last November and opened a new Spectrum account w/ a new modem and router that we’re renting from them— but that was using an even OLDER 2010 Netgear router (I don’t remember if I ever tried getting it back online after I switched it out for a newer phone/left that carrier).
So, any troubleshooting suggestions?? One IT guy I called suggested it could be a "bad network card." Besides that I'm wondering if:
1) I should try hardwiring it into my modem via MicroUSB-to-Ethernet adapter, IF there’s any software I can DL that’d make a difference??
However I did already try Updating the Certificates, PRL, Profile & Motorola software while on my buddy's/the Starbucks Wifis (the System— 7.1.1/Nougat— is up to date).
2) I should try reconnecting/see if it'll work with that old router?
While the one we’re renting is more up-to-date, the only routers Spectrum offers to residential customers these days DON’T have the option to adjust the WPS Push Button/Pin Entry, assuming that could make a difference? (for what it’s worth, my friend’s using a router they purchased on their own Spectrum Wifi, dunno about the one at Starbucks…).
3) I should try adjusting the “Network Restrictions,” “Preferred network type,” Automatic, LTE/CDMA, CDMA, GSM/UMTS, Static/DHCP/etc settings? I already tried doing so to the latter without success.
Needless to say, it’s an older phone; best case scenario if I CAN get it online, I figured I’d turn it into a remote for our old non-“smart” TV.
But for the time being, I'm just left wondering what it is about my Wifi that it doesn't like.
Thanks!!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,611
4,757
113
I stopped renting my modem from Xfinity/Comcast a long time ago. I think their rental fee is around $14/mo these days, or $168/yr, which is a great way for them to make money:-\. I've bought my own compatible modem a couple of times (each time finding one on eBay or Amazon for <$100), and then hook up my Google Wifi mesh router system to it (which works great and is super easy to set up).
I would normally recommend Google Wifi to you, but if you still want to use those older devices, I can't be entirely sure that the same kind of issue won't crop up again. I can say that the oldest device I have (an Honor 8 from 2016) still connects fine.
J Dubbs
4,006
1,145
113
We're also using a Google wifi mesh system... it's running everything from a Dragon Touch tablet running Android 4.4, to an original Kindle that must be about 12 years old, up to my 2015 Moto X Pure Edition, and everything else I've tried on it. I would also highly recommend the system ;)
dxter
