Welcome to Android Central! Can you be more specific about the "going crazy" part? Or is it just the vibration that you're talking about? Are any recurring alarms set? Is this associated with any notifications?
Not only does it continually vibrate but the screen jumps all over and is unusable. I did notice last night that I got a notice for my water intake that has to do with my Samsung Gear Fit, but it might have been a coincidence that they were on at the same time.
