A
AC Question
How to diagnose battery drain on Galaxy S6? Settings->System->Battery->Battery Usage doesn't help
I have a 128 GB Galaxy S6 on Rogers Wireless in Canada. I have an intermittent issue where the phone becomes sluggish, hot, rapidly drains the battery and often will not send or receive SMS. Investigation through Settings->System->Battery->Battery Usage provides no clues. For example, battery depletes in 3h 36m, repored usage is: Screen-6%, Gmail-4%, Android OS-4%, Android System-4%, Google Play Services-4%, Google App-3%, Cell Standby-2%.
I can often resolve the issue by booting into Recovery mode and wiping the cache partition. This fix typically only last for a few days before the problem reappears.
The strange thing is that I experienced exactly the same issue on my Galaxy S3 on the same carrier.
What further investigation can I perform? I suspect that I have a rogue app or maybe corrupt media file.
