Need advice on best size for micro SD card and portable battery charger for Samsung Galaxy s5
A
AC Question
I have a Samsung Galaxy s5. Want to buy and SD card and a portable battery charger. What's the best choices? Going to Disney in 3 weeks and don't want to run out of battery or memory for all the pics and movies I want to take of the grand kids. Many thanks for your advise.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,604
4,753
113
Welcome to Android Central! It depends on how many photos and videos you expect to take. In general, a 32 GB card should be fine, and those are pretty inexpensive nowadays (around $15-20). Samsung says the phone can take up to a 128 GB card, but those can be pretty pricey, and I doubt you need that much storage. I don't have any opinions on portable battery chargers, but you should probably look into getting a spare battery, which you can carry around with you and swap out if you need to during the day.
Non
