A
AC Question
Issue/scenario:
Samsung S4. Phone turns off at any battery level. Won't turn on again.
Status:
- Issue occurs about 1 - 4 times a day.
-phone works fine otherwise
- I dropped my phone once 2 weeks before it started
Short-term fix:
Remove battery. Place in again, connect to charger. Wait, see charging battery sign. Can be turned on again.
Tried:
- Use different battery
- Take out SD card
- Install Lollipop
- Complete Factory Reset ;-(
Also:
- before I was able to start the phone again without using a charger
- it sometimes rebooted randomly
- now it just dies and only jump starts turn it on
Status:
Short-term fix:
Tried:
- Take out SD card
- Install Lollipop
Also:
