will my lg g3 from koodo work on this plan
A
AC Question
looking to see if my LG G3 is compatible with straight talk services or would I need to unlock my phone?????
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It depends on which carrier it's locked to. AT&T and TMobile is no problem - you get the SIM card for the carrier it's locked to. (Straight talk uses all 4 carriers.) If it's a Verizon phone, check at Straight Talk Compatibility Test to see if you can use it. If it's a Sprint phone, the chances are that you can't, but you can still go that site and check.
RandyRoyalty
