I have a Sony Xperia Z1s. It turns on screen looks fine but the screen will not respond to any touches whatsoever. I want to factory reset it but u have to use the touchscreen to do a full factory reset. I checked and the only reset available using only hardware buttons is a regular shutdown or a restart but no factory reset. If anyone out there knows how to fix the touchscreen or factory reset it without using the screen. Is there a way to initiate a factory reset using the USB connection? Any help at all will be greatly appreciated. Thanks.
