Can I successfully charge a Samsung note 4 wireless?
A
AC Question
Needing info about the wireless charging, such as which is best for the Samsung note 4, and how does the sticker you can put on your battery work vs buying a new back cover that is wireless charging g compatible? And is wireless charging worth it? Is it a slow charge or the a am as plugging it in direct? Thanks
tress
