A
AC Question
Hello, I have a samsung, model number GT-19305N.
OS version 4.1.1
When I try to upgrade it through the phone options it gives me the error message: Processing failed
Looked up alternatives, but they require you to plug the phone to the pc, which I can't do, the pc won't detect it, it charges just fine, so the inner part is broken.
So please no suggestions about software that require you to plug it to the pc.
I checked if the phone was perhaps rooted, it was not. I factory reset it, also did not help. I have scoured the net for solutions, but either they are vague in explaining it or it simply doesn't apply to my issue.
OS version 4.1.1
