Hi,
My Transformer TR101 battery has some strange habits.
First it pointed at 98% at every startup, even if I shut it down at 30%, but the usage time still seemed normal, given at what level I had shut it down (always undocked).
Since 2 days the symptoms have changed. After it starts up, and has been shut down at 100%, it goes from 100% to almost 0% in about 10 minutes. Loading it up to 100% again also takes no more than about 10 minutes.
A cold reboot did change nothing.
Asus gives only one year warranty on batteries, and my TR101 is almost 2 years old, so I expect nothing from them.
My battery has been loaded - I guess- about 300 times (every two days during two years). I thought you can load these batteries 500 times, so I would expect a dead battery not within the next 1-2 years.
I consider buying a new battery and venturing the installation myself, because now I can only use my pad plugged in.
Does anybody recognise these symptoms?
