I followed the instructions to boot off an SD card and they worked great. Thanks for all the info. But, one day, I got froggy and decided to play with the Nook Color Tweaks. I was running 1200mhz with no problem but couldn't leave well enough alone. I got in there and started to adjust the frequencies of the lower steps. I didn't changed them alot, but evidently enough to cause it to lock up. I decided start over from scratch. I once again followed all the steps and got it to load from the SD card, saw the penguin and it scrolled through all the stuff. But, when I go to turn the nook back on after the shutdown, it will not boot off the SD card. It will only boot the BN Nook color. I have tried this several times with different builds with no luck. Does anybody have any ideas??
I looked for this question in another forum and could not find something similar, so I posted.
Any help would be greatly appreciated....
