touch screen problems..
jayblazer
91
3
The screen keeps a spot pressed or acts like it is being tapped after i touch a spot. Does anyone have any suggestions? I am running the latest cm7 installed to the nook. Thanks for any help you my may offer.
IanMcB
88
I had the same issue with CM7 and ADW - if I tried to start an app that was in the dock it would act as if I was dragging the icon out onto the desktop. When I switched to Phiremod it stopped for a few days, but yesterday started doing it again.
It didn't do it when I was using Zeam so I will probably switch back. Maybe I need to work on my touchscreen skills.
marcjac
17
I'm not sure if this will help, but I recall reading about some screen recalibration software (free IIRC) on the Market to help with screen sensitivity after rooting. Maybe worth a look??
-Marc
jmunchies1
16
I also had this happenlast night. CM7 nightly 41.
Screen went crazy and seemed like it was stuck on pressed.
All I could do was long press power to shutdown.
slcbtf
58
Mine did the same thing after I installed CM7. I rebooted a couple times and it went away. It hasn't come back since.
jayblazer
91
3
I read a ton of older posts and decided I needed a screen protector. I'm going to give that a shot for a bit and see how it works.. I did download a touch screen recalabrator just in case.. I will let you all know what I come up with..
robt1
Active member
Jan 23, 2011
39
3
Phantom touch stopped completely after I got a screen protector. Mine were so frequent that I thought my nook was damaged.
Sent from my NookColor using Tapatalk
jayblazer
91
3
I have had no problems since yesterday myself.. I was also thinking that mine was a dud.. this should be considerd essential..
tress
