Do they have any longer ones? The one that comes with the phone is like 3-4ft, which is very inconvenient.
What exactly should I search? Micro SD cable didn't yield any results.Its just a standard Micro SD cable. You can buy them dirt cheap on ebay.
So any of the USB 2.0 Cables - Micro-B Type will work?cables: USB Cables
they also have these: For only $1.85 each when QTY 50+ purchased - High-Speed WALL Power to USB Female Converter (1000mA) - White | Power to USB Converters
I wonder if they charge as fast as the stock charger...
yes so please go to monoprice.comSo any of the USB 2.0 Cables - Micro-B Type will work?
Just got the same one you got. Thanks for the help!yes so please go to monoprice.com
best prices for cables
i got a 6ft one for my bionic it was .81 cents
and it works super i get all my cables there
im in California so i get stuff super quick but their service and products are awesome!!!
better yet here is to all the sizes:
USB Cables
and the one i got:
For only $0.68 each when QTY 50+ purchased - 6ft USB 2.0 A Male to Micro 5pin Male 28/28AWG Cable | USB 2.0 Cables - Micro-B Type
glad i could help!Just got the same one you got. Thanks for the help!
Yeah, the site is pretty cool. If only I knew what all that stuff is.glad i could help!
Now you know where to get good cables cheap, also i got a a few TV mounts for me and my family and friends installed all our HD tvs and i paid the same price for 6 tv mounts what i would of paid for 1 or 2 of equal quality at the worstbuy
plus maybe next time if you use your bionic for gps or bedside mode or would like to and think paying 80 for both docks is ridiculous
pick this up from them
For only $3.01 each when QTY 50+ purchased - Universal GPS Car Mount Holder | For Garmin
and the Bionic app from the store for free and you got all 3 modes and can use that dock
i cant speak of the quality as i will be getting mine 2morrow delivered at around 11am so i can post pix if you like and a review after i use it for a few hours
yup right here, my sister bought one for her htc and she gets the same charge timesYeah, the site is pretty cool. If only I knew what all that stuff is.
Is it possible to buy the piece you plug into the wall on monoprice? I assume it would be cheaper to buy the piece and a cord than buy another wall charger from Verizon.
Thanks again bud!yup right here, my sister bought one for her htc and she gets the same charge times
Black is $2.16 but sold out at the moment
For only $1.75 each when QTY 50+ purchased - High-Speed WALL Power to USB Female Converter (1000mA) - Black | Power to USB Converters
White is $2.28
in stock
so you get about a whole charger for $3
Says they are still hold.get the black, the white ones glow almost like a nightlight. If you have an option.
If they both hadn't been discontinued I most likely would've bought a couple. Worked out well that they did get discontinued.Dont waste your money! the second one I ordered died on friday, after just a 7 or 8 hours of use over a two day period. I actually heard it make a popping noise when it went out.
It might just be a fuse, I'm gonna take them apart when i have a chance and see if there is anything worth seeing.
I've got the third one still, haven't used it at all yet, dont think I will, I dont want to risk a failure and having it fry my phone!
