After reading through some of your posts, you all seem pretty helpful, so I decided to sign up here.
I got my Razr M near the beginning of the year after upgrading from my Droid X. I have been using it for months and just recently it tells me that there is insufficient storage to perform updates or other certain operations. I have a 32gb microsd, and was a bit confused until I found that by default it was saving all media and photos to the small internal storage.
When I figured that out, I went to plug my Razr M into my PC to move the files over to the card. Nothing.
I installed Motorola's drivers. Nothing.
Made sure I had the right cord...(The Original One) I did...Nothing. It charges from the wall with this cord...
Nobody has been helpful, I've read through several related dead end forum posts with dumbfounded people just giving up.
I am running Windows 7 64 bit Ultimate, but I have also tried on several other PC's, nothing there either. Nothing from the phone or the PC, like it was never plugged in.
This phone has also never been rooted or modified, USB debugging and mock locations are on.
Any help?
Thanks!
Any help?
Thanks!
