DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 3 of 3
    Default Smart Actions Battery Extender
    Hey there guys
    Just wondering if anyone else is having issues with the battery extender option triggering? Its not for me at all. It went earlier today 10 minutes with no movement or use and the action didn't trigger. Kind of frustrating. Anyone got any ideas on how to get it to trigger?
  2. #2
    Default Re: Smart Actions Battery Extender
    I had that issue at one point. I simple went into smart actions and disabled the rule and then re-enabled the rule and it was fine. to disable it just go into smart actions and touch the icon to the left of the rule.
  3. #3
    In gb I could use sa battery extender and stream MLB AT BAT, OR PANDORA or other streaming app, and it would continue after my screen went dark, any ideas on how to get that back?
