So I found this Droid RAZR that doesn't work, but after some time I fixed it. Now the problems coming back. Basically, the screen turns off, and the higher the battery, the longer it takes for it to once again be chargeable. Usually this is 1 1/2-3 days to work. Also, the battery is always at 0 when it starts to charge with the battery symbol, indicating the battery must need to be at 0 for it to start charging. On another note, when I does work I got errors for uuid and it asks me if I'm "feeling lucky" sometimes. Finally, the case won't fully pop in at the top. It usually powers off in this way when it's lower, but has happened at 80%.
Things I've tried so far is hard reset, soft reset (held for about a minute) and the power button. I am desperate to get this fixed.
