Car Dock - Two Issues (BT and Calling)
Fletchand
Active member
Jul 13, 2010
44
When my phone is in the Moto Car Dock I am experiencing two problems:
1) When I press my BT Headset to voice dial, the computer voice "say a command" is very faint and distorted. Works fine out of the dock though?? Using a Jawbone Icon if that makes a difference.
2) When I push the "Calling" icon it flashes but stays on that screen. I did set the custom button to dialer to make sure it works and it does. Any ideas?
Any and all help is appreciated. Thanks.
-Fletch&
SamMyers
3
I've been having the same issue with the "faint" Say-A-Command. However, it is only intermittent.
Also, I find that, at times, even though my bluetooth shows connected, it's actually using speaker phone. This is a total pain in the rear. I usually have to turn off both my Jawbone Icon, and the bluetooth on the phone, then turn them all back on. Sometimes it will repeat this, in which case I do it all over again.
Quite annoying!
Fletchand
Active member
Jul 13, 2010
44
update...
Seemed to work better on the way home tonight. Very strange.
Anyone have any ideas on problem #2, is there a way to re-install that app?
Thanks,
Fletch&
tivativa
