Results 1 to 3 of 3
    Default Screen won't rotate
    I ahve a new Motorola Droid three and the screen stopped rotating when on the home screen...unless the keyboard is open. It rotates when apps. need it to but not when the keyboard is closed on the home screens.Is there a setting that got changed by an app?
  2. #2
    Default
    I'm a Droid noob but my inc2 came like that. It might be an OS thing. Did you upgrade recently? And you are sure it was rotating before?
    sent from my DInc2 with Tapatalk
  3. #3
    shanshor's Avatar
    Posts
    Global Posts
    146 Global Posts
    Default
    I don't have an android phone but I've payed enough attention to them to be able to confidently say that it is not supposed to rotate on the home screen unless the keyboard is open. That's why it works for your other apps.
