Hi,
I figured it out - it seems counter intuitive....
Normally, I expect to configure something before turning it on. Here, setting the Hotspot parameters, then turning the hotspot on seems to reset the hotspot settings.
Turning on the hotspot, then enter the configure options seems to stick, even across reboots.
Problem solved!
Cheers,
Tim
