I used a Pre for a while but haven't had it in some time. I seem to remember that you could merge contacts into a single entity...in other words, if you have multiple contact entries for the same person, you could merge them into a single entry. That way, you would be consolidating all of their information into a single place.
Is this possible to do on the Evo? I cannot seem to find it.
Thanks in advance!
Thanks in advance!
