DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 5 of 5
    Default SD Card Help
    I've been very familiar with Android for a while, but I've been a power user for about only a couple months. Since I've started using my phone more I've found that I need more space on my phone. My RAZR came with a 16GB microSD but it was crap and no matter what I do I haven't been able to get it to work. So I'm going to buy another one, but what I don't know is all the different types of microSD cards out there. I know there are different classes, and I know there's microSDHC and microSDXC and I don't know which is compatible with my phone. I also have heard you can do something like formatting the micrSDXC to work like a microSDHC. So if someone could explain all of this to me that would be great. Also any tips about what I can do to optimize my phone and the card would be appreciated.
    Much thanks,
    Conman
  2. Thread Author  Thread Author    #2
    Default
    Anyone?
    Sent from my DROID RAZR
  3. #3
    Swavek's Avatar
    Posts
    Global Posts
    134 Global Posts
    ROM
    stock
    Default
    I could be wrong, but microsdhc are memory cards upto 32 gb. microsdxc is 64 gb (and higher perhaps but 64 gb is the largest that I've seen)
    officially most or all android phones support upto 32 gb microsd cards but Android Police had tested some 64 cards but I don't remember what. phone they used.
    as for formatting an sdxc to make it compatible like a sdhc, I don't know.
  4. #4
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,828 Global Posts
    ROM
    BB JB
    Default Re: SD Card Help
    Swavek is correct. sdhc is for up to 32gb and sdxc is for higher capacity.
    Sandisk has always been my memory of choice but patriot is starting to make some nice cards as well.
    Most manufacturer's carry a 3 year warranty on microsd cards which entitles you to a free replacement.
    And don't buy any memory cards off of ebay...it's like the golden rule of memory cards. Too many fakes!
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  5. #5
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by tony bag o donuts View Post
    You can usually find them dirt cheap on Amazon or Newegg anyway. Just gotta keep your eyes open and maybe wait a little.
