takeshi is right. another thing you can do (which i think works better because it helps not waste so much space on the home screen) is to use the folder app called "live bookmarks". you can download it in the market for free and what it does is it displays 1 folder on your homescreen and when you open that folder a list of all of you bookmarks pops up that you can scroll up and down to see all of them and then select the one you want to use
